Zum Hauptinhalt wechseln
DualShock 4 Controller Rumble Motors Replacement
Was du brauchst
  1. DualShock 4 Controller Rumble Motors Replacement, Rumble Motors: Schritt 1, Bild 1 von 1
    • Remove the four 2mm screws on the rear plate using the #000 Phillips screwdriver.
  2. DualShock 4 Controller Rumble Motors Replacement: Schritt 2, Bild 1 von 1
    • Remove the rear plate.
    • We recommend using a metal spudger for this step.
  3. DualShock 4 Controller Rumble Motors Replacement: Schritt 3, Bild 1 von 2 DualShock 4 Controller Rumble Motors Replacement: Schritt 3, Bild 2 von 2
    • Desolder the joints that attach the rumble motors to the motherboard.
    • For more information on soldering, click here.
  4. DualShock 4 Controller Rumble Motors Replacement: Schritt 4, Bild 1 von 2 DualShock 4 Controller Rumble Motors Replacement: Schritt 4, Bild 2 von 2
    • There is a hidden screw underneath the battery pack that attaches the faceplate to the motherboard.
    • Lift the pack and remove the 10mm screw using the #000 Phillips screwdriver.
  5. DualShock 4 Controller Rumble Motors Replacement: Schritt 5, Bild 1 von 1
    • Remove the faceplate from the motherboard.
  6. DualShock 4 Controller Rumble Motors Replacement: Schritt 6, Bild 1 von 3 DualShock 4 Controller Rumble Motors Replacement: Schritt 6, Bild 2 von 3 DualShock 4 Controller Rumble Motors Replacement: Schritt 6, Bild 3 von 3
    • With some added pressure, push down and outward in order to free and remove the rumble motors from their socket.
Abschluss
13 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
I’d recommend adding removal instructions for the touchpad also
AlexMorse - Antwort
the rumble packs are stuck with an adhesive on my controller. The best way to remove the rumble pack in this case? thanks
Ka Erd - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 62
Letzte 30 Tage: 241
Insgesamt: 24,408
