Zum Hauptinhalt wechseln
Dyson V8 Absolute Bin Replacement
Was du brauchst
  1. Dyson V8 Absolute Bin Replacement, Bin: Schritt 1, Bild 1 von 1
    • Set the device upright on a flat surface and detach the wand.
    • Pull the red bin release trigger, on top of the cyclone. This will require some force.
  2. Dyson V8 Absolute Bin Replacement: Schritt 2, Bild 1 von 2 Dyson V8 Absolute Bin Replacement: Schritt 2, Bild 2 von 2
    • Pull up on the latch until it's fully extend.
    • The bin will open to dispense debris once the red latch is pulled.
  3. Dyson V8 Absolute Bin Replacement: Schritt 3, Bild 1 von 2 Dyson V8 Absolute Bin Replacement: Schritt 3, Bild 2 von 2
    • Push the red circular button to release the latch on the cyclone.
    • The cyclone should release and be fully detached from the device.
  4. Dyson V8 Absolute Bin Replacement: Schritt 4, Bild 1 von 2 Dyson V8 Absolute Bin Replacement: Schritt 4, Bild 2 von 2
    • Push on the red release button on the bottom of the bin.
    • The bin should slide away from the handle.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
UW Tacoma, Team S1-G5, Rose Fall 2017 Mitglied von UW Tacoma, Team S1-G5, Rose Fall 2017
UWT-ROSE-F17S1G5
4 Mitglieder
15 Anleitungen geschrieben
2 Kommentare
My bin seems to be more difficult to open all of the sudden and I have taken it all apart and put it back together. Still having the issue where the bin doesnt open when the cyclone pops up. HELP please
Rob Coughlin - Antwort
I have a Dyson v8 and the red release button is stuck. What do I do.
Pamela Wanklyn - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 31
Letzte 30 Tage: 137
Insgesamt: 20,356
