Zum Hauptinhalt wechseln
Garmin Nuvi 1390LMT Battery Replacement
Was du brauchst
  1. Garmin Nuvi 1390LMT Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Snap the plastic cover off using a plastic opening tool.
  2. Garmin Nuvi 1390LMT Battery Replacement: Schritt 2, Bild 1 von 2 Garmin Nuvi 1390LMT Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove the four black 11 mm T5 torx screws.
  3. Garmin Nuvi 1390LMT Battery Replacement: Schritt 3, Bild 1 von 1
    • Pop the screen cover off with a plastic opening tool.
  4. Garmin Nuvi 1390LMT Battery Replacement: Schritt 4, Bild 1 von 2 Garmin Nuvi 1390LMT Battery Replacement: Schritt 4, Bild 2 von 2
    • Flip the screen over out of the case.
    • Be sure not to twist or damage the wiring harness connecting the screen to the circuit board.
  5. Garmin Nuvi 1390LMT Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the two silver 5 mm T5 torx screws connecting the circuit board to the plastic casing.
  6. Garmin Nuvi 1390LMT Battery Replacement: Schritt 6, Bild 1 von 2 Garmin Nuvi 1390LMT Battery Replacement: Schritt 6, Bild 2 von 2
    • Flip the circuit board over onto the screen.
  7. Garmin Nuvi 1390LMT Battery Replacement: Schritt 7, Bild 1 von 1
    • Disconnect the harness between the battery and the circuit board.
  8. Garmin Nuvi 1390LMT Battery Replacement: Schritt 8, Bild 1 von 2 Garmin Nuvi 1390LMT Battery Replacement: Schritt 8, Bild 2 von 2
    • Peel the battery from the plastic back with a plastic opening tool.
    • It is connected with a glue so be careful.
Ziellinie
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Trey Ulsh
537 Reputation
3 Anleitungen geschrieben
Montana Tech, Team 10-4, Shirk Fall 2015 Mitglied von Montana Tech, Team 10-4, Shirk Fall 2015
MTUM-SHIRK-F15S10G4
5 Mitglieder
Ein Kommentar
Great guide and very informative. Here is a replacement battery that is reasonably priced and it comes with all of the tools needed for installation. It even has a 1 year replacement warranty!
Nuvi 1390 Battery 361-00019-16
Mike - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 21
Insgesamt: 3,792
