Zum Hauptinhalt wechseln
GoPro Hero Battery Replacement
Was du brauchst
  1. GoPro Hero Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero Battery Replacement: Schritt 2, Bild 1 von 1
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero Battery Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
    • Use a plastic spudger to pry the battery off from the white plastic piece underneath.
    • The battery is glued to the plastic so some force might be necessary.
    • Be careful not to damage the battery to avoid releasing dangerous chemicals.
  4. GoPro Hero Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery from the GoPro.
Abschluss
27 weitere Nutzer:innen haben diese Anleitung absolviert.
River Drake
1.035 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 12-2, Lancaster Spring 2015 Mitglied von Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Mitglieder
18 Anleitungen geschrieben
20 Kommentare
The tutorial is excellent, even with a link to the tools needed, but no link to battery sale.
Could you please include this?
juliomap - Antwort
Very good tutorial thank you. But I can also find no place to buy a new battery... But here is a petition to make Gopro sell spare parts: https://www.change.org/p/gopro-support-o...
maire - Antwort
I followed these steps and inadvertently pulled not only the battery plug but its adapter (housing) at the same time. Now I can't plug the battery back in because there's no place to plug it! Contacting GoPro they stressed that the battery is not intended for removal.
erikwikstrom - Antwort
Awesome! Could you also show us how to put in a new battery, how do i prep my battery? What type of a battery can i use ? Thanks a lot !!
John misquita - Antwort
now add go pro to rice for a day and pray.
chadd23 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 64
Letzte 30 Tage: 281
Insgesamt: 76,564
