Zum Hauptinhalt wechseln
HP Chromebook 11 G3 Display Assembly Replacement
Was du brauchst
  1. HP Chromebook 11 G3 Display Assembly Replacement, Keyboard Mount: Schritt 1, Bild 1 von 2 HP Chromebook 11 G3 Display Assembly Replacement, Keyboard Mount: Schritt 1, Bild 2 von 2
    • Flip the laptop upside down so that the lid lies flat on the table.
    • Remove the nine 6mm Phillips #00 screws that line the border.
  2. HP Chromebook 11 G3 Display Assembly Replacement: Schritt 2, Bild 1 von 2 HP Chromebook 11 G3 Display Assembly Replacement: Schritt 2, Bild 2 von 2
    • Remove the two rubber feet closest to the hinge using tweezers.
    • Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
    • The rubber feet may tear while removal; preventing this can be difficult, but it won’t harm the laptop. If desired, replace these rubber feet during reassembly.
  3. HP Chromebook 11 G3 Display Assembly Replacement: Schritt 3, Bild 1 von 1
    • Flip the laptop so it is in the upright position.
    • Open the lid.
    • Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
    • This may require more force than expected. Hearing loud clicks as the plastic opening tool slides along the seam is normal.
  4. HP Chromebook 11 G3 Display Assembly Replacement: Schritt 4, Bild 1 von 3 HP Chromebook 11 G3 Display Assembly Replacement: Schritt 4, Bild 2 von 3 HP Chromebook 11 G3 Display Assembly Replacement: Schritt 4, Bild 3 von 3
    • Tilt the keyboard mount up.
    • Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
    • Gently remove both ribbon cables.
  5. HP Chromebook 11 G3 Display Assembly Replacement: Schritt 5, Bild 1 von 1
    • Lift the keyboard mount out of the laptop.
  6. HP Chromebook 11 G3 Display Assembly Replacement, Display Assembly: Schritt 6, Bild 1 von 1
    • Gently tug on the black and white wires connected to the Wi-Fi module to disconnect them.
  7. HP Chromebook 11 G3 Display Assembly Replacement: Schritt 7, Bild 1 von 2 HP Chromebook 11 G3 Display Assembly Replacement: Schritt 7, Bild 2 von 2
    • Using a spudger, lift the ZIF retaining flap that secures the display’s ribbon cable to the motherboard.
    • Gently pull the ribbon cable out of its socket.
  8. HP Chromebook 11 G3 Display Assembly Replacement: Schritt 8, Bild 1 von 1
    • Free the wire from the casing.
  9. HP Chromebook 11 G3 Display Assembly Replacement: Schritt 9, Bild 1 von 1
    • Remove the two 6mm Phillips #00 screws located near the upper left and right corners of the hinge mounts.
    • Hold the lid so that it is folded slightly inwards while removing the screws so that the lid doesn’t fall.
  10. HP Chromebook 11 G3 Display Assembly Replacement: Schritt 10, Bild 1 von 1
    • Rotate the lid to a 90-degree angle with the table.
    • Shimmy the lid out of the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Rahul Goyal
1.369 Reputation
10 Anleitungen geschrieben
Cal Poly, Team S23-G3, Livingston Spring 2017 Mitglied von Cal Poly, Team S23-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G3
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 16
Insgesamt: 1,483
