Zum Hauptinhalt wechseln
HP Chromebook 11 G3 SD Card Reader Module Replacement
Was du brauchst
  1. HP Chromebook 11 G3 SD Card Reader Module Replacement, Keyboard Mount: Schritt 1, Bild 1 von 2 HP Chromebook 11 G3 SD Card Reader Module Replacement, Keyboard Mount: Schritt 1, Bild 2 von 2
    • Flip the laptop upside down so that the lid lies flat on the table.
    • Remove the nine 6mm Phillips #00 screws that line the border.
  2. HP Chromebook 11 G3 SD Card Reader Module Replacement: Schritt 2, Bild 1 von 2 HP Chromebook 11 G3 SD Card Reader Module Replacement: Schritt 2, Bild 2 von 2
    • Remove the two rubber feet closest to the hinge using tweezers.
    • Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
    • The rubber feet may tear while removal; preventing this can be difficult, but it won’t harm the laptop. If desired, replace these rubber feet during reassembly.
  3. HP Chromebook 11 G3 SD Card Reader Module Replacement: Schritt 3, Bild 1 von 1
    • Flip the laptop so it is in the upright position.
    • Open the lid.
    • Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
    • This may require more force than expected. Hearing loud clicks as the plastic opening tool slides along the seam is normal.
  4. HP Chromebook 11 G3 SD Card Reader Module Replacement: Schritt 4, Bild 1 von 3 HP Chromebook 11 G3 SD Card Reader Module Replacement: Schritt 4, Bild 2 von 3 HP Chromebook 11 G3 SD Card Reader Module Replacement: Schritt 4, Bild 3 von 3
    • Tilt the keyboard mount up.
    • Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
    • Gently remove both ribbon cables.
  5. HP Chromebook 11 G3 SD Card Reader Module Replacement: Schritt 5, Bild 1 von 1
    • Lift the keyboard mount out of the laptop.
  6. HP Chromebook 11 G3 SD Card Reader Module Replacement, SD Card Reader Module: Schritt 6, Bild 1 von 2 HP Chromebook 11 G3 SD Card Reader Module Replacement, SD Card Reader Module: Schritt 6, Bild 2 von 2
    • On the module, use a spudger to lift the small ZIF retaining flap for the ribbon cable connecting the SD card reader to the motherboard.
    • Gently pull the ribbon cable out of its socket.
  7. HP Chromebook 11 G3 SD Card Reader Module Replacement: Schritt 7, Bild 1 von 1
    • Remove the two Phillips #00 6mm screws that attach the module to the laptop.
  8. HP Chromebook 11 G3 SD Card Reader Module Replacement: Schritt 8, Bild 1 von 1
    • Lift the module up and out of the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Rahul Goyal
1.369 Reputation
10 Anleitungen geschrieben
Cal Poly, Team S23-G3, Livingston Spring 2017 Mitglied von Cal Poly, Team S23-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G3
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 19
Insgesamt: 415
