Zum Hauptinhalt wechseln
HP Chromebook 11 G4 SD Card Reader Replacement
Was du brauchst
  1. HP Chromebook 11 G4 SD Card Reader Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Position the closed Chromebook with the rubber pads are facing up.
  2. HP Chromebook 11 G4 SD Card Reader Replacement: Schritt 2, Bild 1 von 2 HP Chromebook 11 G4 SD Card Reader Replacement: Schritt 2, Bild 2 von 2
    • Slide the flat end of the spudger under the rubber pads at the upper right-hand and the upper left-hand corners.
    • Pry off the rubber pads to reveal a screw under each pad.
    • The rubber pads are attached with a strong adhesive. The force applied may damage the pads.
  3. HP Chromebook 11 G4 SD Card Reader Replacement: Schritt 3, Bild 1 von 2 HP Chromebook 11 G4 SD Card Reader Replacement: Schritt 3, Bild 2 von 2
    • Remove the eleven 6mm Phillips #1 screws.
  4. HP Chromebook 11 G4 SD Card Reader Replacement: Schritt 4, Bild 1 von 1
    • Flip over the Chromebook and open it.
  5. HP Chromebook 11 G4 SD Card Reader Replacement: Schritt 5, Bild 1 von 2 HP Chromebook 11 G4 SD Card Reader Replacement: Schritt 5, Bild 2 von 2
    • Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body.
    • Slide the spudger along the gap, applying downward pressure to separate the two components.
    • You should hear popping sounds as you slide the spudger along the edge.
    • If the spudger gets stuck while sliding, simply slide the spudger back for a bit, and continue sliding forward.
  6. HP Chromebook 11 G4 SD Card Reader Replacement: Schritt 6, Bild 1 von 1
    • Lift the bottom of the keyboard assembly to reveal the internal components of the device.
  7. HP Chromebook 11 G4 SD Card Reader Replacement: Schritt 7, Bild 1 von 3 HP Chromebook 11 G4 SD Card Reader Replacement: Schritt 7, Bild 2 von 3 HP Chromebook 11 G4 SD Card Reader Replacement: Schritt 7, Bild 3 von 3
    • Use the pointed end of the spudger to flip up the black tabs on the two ZIF connectors located on the motherboard.
    • Disconnect the ribbon cables from the motherboard by gently sliding them out of their sockets.
  8. HP Chromebook 11 G4 SD Card Reader Replacement: Schritt 8, Bild 1 von 1
    • Remove the keyboard assembly by lifting it off the laptop base.
  9. HP Chromebook 11 G4 SD Card Reader Replacement, SD Card Reader: Schritt 9, Bild 1 von 3 HP Chromebook 11 G4 SD Card Reader Replacement, SD Card Reader: Schritt 9, Bild 2 von 3 HP Chromebook 11 G4 SD Card Reader Replacement, SD Card Reader: Schritt 9, Bild 3 von 3
    • Flip up the flap on the ZIP connector with your finger.
    • Gently pull out the ribbon cable.
  10. HP Chromebook 11 G4 SD Card Reader Replacement: Schritt 10, Bild 1 von 2 HP Chromebook 11 G4 SD Card Reader Replacement: Schritt 10, Bild 2 von 2
    • Remove the two 4 mm Phillips #1 screws.
  11. HP Chromebook 11 G4 SD Card Reader Replacement: Schritt 11, Bild 1 von 2 HP Chromebook 11 G4 SD Card Reader Replacement: Schritt 11, Bild 2 von 2
    • Lift the ribbon cable back and out of the way.
    • Pull out the SD card reader.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Jair Herrera
694 Reputation
4 Anleitungen geschrieben
Cal Poly, Team S16-G5, Banghart Winter 2018 Mitglied von Cal Poly, Team S16-G5, Banghart Winter 2018
CPSU-BANGHART-W18S16G5
5 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 10
Letzte 30 Tage: 18
Insgesamt: 1,058
