Zum Hauptinhalt wechseln
HP Envy TouchSmart 15 Wireless Adapter Replacement
Was du brauchst
  1. HP Envy TouchSmart 15 Wireless Adapter Replacement, Battery: Schritt 1, Bild 1 von 1
    • Press the battery release tab and the battery will pop up.
  2. HP Envy TouchSmart 15 Wireless Adapter Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery from the laptop, it will come out easily.
  3. HP Envy TouchSmart 15 Wireless Adapter Replacement, Accessory Plate: Schritt 3, Bild 1 von 2 HP Envy TouchSmart 15 Wireless Adapter Replacement, Accessory Plate: Schritt 3, Bild 2 von 2
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
  4. HP Envy TouchSmart 15 Wireless Adapter Replacement: Schritt 4, Bild 1 von 3 HP Envy TouchSmart 15 Wireless Adapter Replacement: Schritt 4, Bild 2 von 3 HP Envy TouchSmart 15 Wireless Adapter Replacement: Schritt 4, Bild 3 von 3
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
  5. HP Envy TouchSmart 15 Wireless Adapter Replacement, Wireless Adapter: Schritt 5, Bild 1 von 2 HP Envy TouchSmart 15 Wireless Adapter Replacement, Wireless Adapter: Schritt 5, Bild 2 von 2
    • Remove the screw with PH 0 screwdriver that is holding the wireless adapter in. This is PM 2.0x2.5 screws.
  6. HP Envy TouchSmart 15 Wireless Adapter Replacement: Schritt 6, Bild 1 von 3 HP Envy TouchSmart 15 Wireless Adapter Replacement: Schritt 6, Bild 2 von 3 HP Envy TouchSmart 15 Wireless Adapter Replacement: Schritt 6, Bild 3 von 3
    • Hold the wireless adapter and gently remove the white and black wires from it. The connectors will come out straight up.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 2-6, Sullivan Fall 2015 Mitglied von USF Tampa, Team 2-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G6
4 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Hi, I use this exact laptop but my wifi card was changed and it didn’t come with Bluetooth so i wanted to know if this
https://www.aliexpress.com/item/Dual-Ban...
can work for me and if its OK to buy it. Thanks
temidayoabayomizannu - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 24
Insgesamt: 3,116
