Zum Hauptinhalt wechseln
HP Pavilion dv6000 LCD Screen Replacement
Was du brauchst
  1. HP Pavilion dv6000 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 1 von 2 HP Pavilion dv6000 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 2 von 2
    • Remove rubber screw covers from the LCD screen. The top covers pop off with a fingernail but the two on the bottom may require a screwdriver or flat tool.
    • Remove the six 7.15mm screws underneath the stoppers. There are four on top and two on bottom.
  2. HP Pavilion dv6000 LCD Screen Replacement: Schritt 2, Bild 1 von 2 HP Pavilion dv6000 LCD Screen Replacement: Schritt 2, Bild 2 von 2
    • Press the tabs on the sides of the screen in and pop the plastic off. Careful, the plastic is very flimsy and may break.
  3. HP Pavilion dv6000 LCD Screen Replacement: Schritt 3, Bild 1 von 2 HP Pavilion dv6000 LCD Screen Replacement: Schritt 3, Bild 2 von 2
    • Remove the two screws (5.8mm) on either side of the LCD near the hinge. Remove the screws on the outermost side first.
  4. HP Pavilion dv6000 LCD Screen Replacement: Schritt 4, Bild 1 von 2 HP Pavilion dv6000 LCD Screen Replacement: Schritt 4, Bild 2 von 2
    • Take out the two 3.58mm screws on the LCD at the top (one on each edge).
  5. HP Pavilion dv6000 LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Hold on to the LCD screen to prevent it from falling over and remove the two 3.58mm screws on the sides at the bottom.
  6. HP Pavilion dv6000 LCD Screen Replacement: Schritt 6, Bild 1 von 3 HP Pavilion dv6000 LCD Screen Replacement: Schritt 6, Bild 2 von 3 HP Pavilion dv6000 LCD Screen Replacement: Schritt 6, Bild 3 von 3
    • Let the screen gently rest on the keyboard.
    • Remove the tape from the ribbon.
    • Stop here and check the cable
Abschluss
15 weitere Nutzer:innen haben diese Anleitung absolviert.
Ben Hirsch
3.826 Reputation
10 Anleitungen geschrieben
Cal Poly, Team 21-33, Regan Fall 2010 Mitglied von Cal Poly, Team 21-33, Regan Fall 2010
CPSU-REGAN-F10S21G33
4 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
after replacing my cracked screen the back light does not show again
firelionkofi - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 27
Insgesamt: 39,298
