Einleitung
If you need to replace your HP Pavilion x360 14-ba253cl display, use this guide to do so. The Digitizer is also connected to the LCD screen, so both can be removed together and bought together. For this guide you will need an opening pick and tweezers. Gloves can be used to protect your hands from contact with any misplaced glass. Power down your laptop before beginning this guide.
Was du brauchst
Insert an opening pick between the screen and top case to separate it from the laptop.
Once the screen is pryed away from the laptop, lay the screen face down onto the keyboard.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
This didn't help at all... You took as little pics as possible and didn't show the reinstall.
