Zum Hauptinhalt wechseln
HP ProBook 650 G2 Battery Replacement
Was du brauchst
  1. HP ProBook 650 G2 Battery Replacement, Remove the case screws: Schritt 1, Bild 1 von 1
    • There are 8 case screws that all use a PH1 bit
  2. HP ProBook 650 G2 Battery Replacement, Pry open the case: Schritt 2, Bild 1 von 3 HP ProBook 650 G2 Battery Replacement, Pry open the case: Schritt 2, Bild 2 von 3 HP ProBook 650 G2 Battery Replacement, Pry open the case: Schritt 2, Bild 3 von 3
    • Start at the back near the hinge with a pry tool
    • Work your way around to the front using enough pressure to release the plastic clips
    • Once you get near the opposite corner it should release to a point where you can use your hand to pull it open
  3. HP ProBook 650 G2 Battery Replacement, Remove the battery: Schritt 3, Bild 1 von 2 HP ProBook 650 G2 Battery Replacement, Remove the battery: Schritt 3, Bild 2 von 2
    • There are 7 captive screws (on the original HP battery) around the edge of the battery that use a PH1 bit
    • Once the screws are removed you can use the tab nearest the front center of the laptop to lift the battery up and out
  4. HP ProBook 650 G2 Battery Replacement, (Optional) Remove captive screws: Schritt 4, Bild 1 von 1
    • If your new battery did not come with the captive screws you can unscrew them from the old battery by applying pressure under the screw while unscrewing them so you can transfer them to the new battery
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
The Bearded IT Guy
136 Reputation
1 Anleitung geschrieben
1 Kommentar zur Anleitung
Just like iFixIt, your guide is precision itself.
Ramelv - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 49
Insgesamt: 1,154
