Einleitung
Is your HP Spectre x360 13-aw0xxx not maintaining power and dying quickly? If so use this guide to help you replace your battery step by step. You will need two opening tools, a Phillips #00 screwdriver, and a T5 Torx screwdriver to complete this replacement.
Was du brauchst
Remove the following screws securing the lower case:
Four Phillips #00 6 mm screws
Two T5 Torx 3 mm screws
Insert an opening tool in the seam between the lower case and chassis.
Pry around the perimeter until the lower case fully releases.
Remove the lower case.
Use two opening tools, one on either side of the battery plug, to slowly pull the plug straight out of its port.
Use a Phillips #00 screwdriver to remove the six 2.5 mm screws securing the battery.
Carefully lift the edge of the battery with an opening tool.
Lift the battery up and out.
