Zum Hauptinhalt wechseln
HP Spectre x360 13t-4000 Battery Replacement
Was du brauchst
  1. HP Spectre x360 13t-4000 Battery Replacement, Bottom Cover: Schritt 1, Bild 1 von 2 HP Spectre x360 13t-4000 Battery Replacement, Bottom Cover: Schritt 1, Bild 2 von 2
    • Turn off and unplug the laptop.
    • Flip over the laptop so that the bottom backplate is exposed.
  2. HP Spectre x360 13t-4000 Battery Replacement: Schritt 2, Bild 1 von 2 HP Spectre x360 13t-4000 Battery Replacement: Schritt 2, Bild 2 von 2
    • Use a T5 screwdriver to remove the six 3 mm screws that secure the backplate.
    • Use the same screwdriver to remove the two 7 mm screws.
  3. HP Spectre x360 13t-4000 Battery Replacement: Schritt 3, Bild 1 von 3 HP Spectre x360 13t-4000 Battery Replacement: Schritt 3, Bild 2 von 3 HP Spectre x360 13t-4000 Battery Replacement: Schritt 3, Bild 3 von 3
    • Insert an opening tool under the bottom cover at the screen hinges, and gently pry the cover free.
    • Carefully work your way around the cover's edges to pop it off completely.
  4. HP Spectre x360 13t-4000 Battery Replacement, Battery: Schritt 4, Bild 1 von 3 HP Spectre x360 13t-4000 Battery Replacement, Battery: Schritt 4, Bild 2 von 3 HP Spectre x360 13t-4000 Battery Replacement, Battery: Schritt 4, Bild 3 von 3
    • With the backplate removed, remove the four 3 mm screws securing the battery with a Phillips #1 screwdriver.
    • With the screws removed, disconnect the 3 wires connected to the battery.
    • Tweezers may be needed to remove the wires.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team S2-G4, Simcock Spring 2019 Mitglied von UMass Dartmouth, Team S2-G4, Simcock Spring 2019
UMASSD-SIMCOCK-S19S2G4
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 28
Insgesamt: 11,553
