Einleitung
If the front facing camera has become nonfunctional, it may be replaced. It is easy to check if the front facing camera is faulty; if the screen does not display an image when the front facing camera is activated via the camera application, then it is likely faulty and responsible. It may be replaced by following this step-by-step guide.
Was du brauchst
Use spudger tool to pry under the battery to lift it up and out.
Pry the back panel of the screen using the plastic opener.
Work your way gently around the device, using picks as necessary to keep the back panel separated.
Remove the 3mm PH00 screw located at the bottom center of the motherboard using a P#00 Phillip's head screwdriver.
