Zum Hauptinhalt wechseln
HTC One X Plus Battery Replacement
Was du brauchst
  1. HTC One X Plus Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power off your device.
    • Insert a pin, paper clip, or very small piece of metal into the hole next to the micro SIM card holder to remove it.
    • The SIM card slot is located on the top edge of the device.
  2. HTC One X Plus Battery Replacement: Schritt 2, Bild 1 von 3 HTC One X Plus Battery Replacement: Schritt 2, Bild 2 von 3 HTC One X Plus Battery Replacement: Schritt 2, Bild 3 von 3
    • Using plastic opening tools, pry open the bottom of the device first.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached use the suction cup tool to remove the screen completely from the black casing.
  3. HTC One X Plus Battery Replacement: Schritt 3, Bild 1 von 3 HTC One X Plus Battery Replacement: Schritt 3, Bild 2 von 3 HTC One X Plus Battery Replacement: Schritt 3, Bild 3 von 3
    • Remove the five 2.4mm screws using a Phillips head screw driver and then remove the plastic cover.
  4. HTC One X Plus Battery Replacement: Schritt 4, Bild 1 von 3 HTC One X Plus Battery Replacement: Schritt 4, Bild 2 von 3 HTC One X Plus Battery Replacement: Schritt 4, Bild 3 von 3
    • Remove the two 3.4 mm JIS #000 screws from the PCB board.
    • Remove the PCB board and antenna.
  5. HTC One X Plus Battery Replacement: Schritt 5, Bild 1 von 2 HTC One X Plus Battery Replacement: Schritt 5, Bild 2 von 2
    • Use tweezers to disconnect the power button flex cable.
    • Disconnect the touch screen flex cable
  6. HTC One X Plus Battery Replacement: Schritt 6, Bild 1 von 3 HTC One X Plus Battery Replacement: Schritt 6, Bild 2 von 3 HTC One X Plus Battery Replacement: Schritt 6, Bild 3 von 3
    • Disconnect the battery from the logic board by detaching the six pin connector.
    • Remove the battery by pulling upwards.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 3-3, Eyestone Fall 2015 Mitglied von USF Tampa, Team 3-3, Eyestone Fall 2015
USFT-EYESTONE-F15S3G3
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 4,063
