Zum Hauptinhalt wechseln
TiVo Series 2 TCD24008A Power Supply Replacement
Was du brauchst
  1. TiVo Series 2 TCD24008A Power Supply Replacement, Cover: Schritt 1, Bild 1 von 1
    • Unscrew the five 0.31 inch T-9 screws on the back cover.
  2. TiVo Series 2 TCD24008A Power Supply Replacement: Schritt 2, Bild 1 von 1
    • Slide the cover towards the back until it is no longer under the front cover.
  3. TiVo Series 2 TCD24008A Power Supply Replacement: Schritt 3, Bild 1 von 1
    • Lift the cover up and off the device.
  4. TiVo Series 2 TCD24008A Power Supply Replacement, Power Supply: Schritt 4, Bild 1 von 1
    • Locate the power supply.
  5. TiVo Series 2 TCD24008A Power Supply Replacement: Schritt 5, Bild 1 von 1
    • Remove the belt connecting the power supply to the motherboard by pulling it out.
  6. TiVo Series 2 TCD24008A Power Supply Replacement: Schritt 6, Bild 1 von 1
    • Remove the red, yellow, and black cable connecting the power supply to the hard drive.
  7. TiVo Series 2 TCD24008A Power Supply Replacement: Schritt 7, Bild 1 von 1
    • Remove the two 0.31 inch T-9 screws from the power supply.
  8. TiVo Series 2 TCD24008A Power Supply Replacement: Schritt 8, Bild 1 von 2 TiVo Series 2 TCD24008A Power Supply Replacement: Schritt 8, Bild 2 von 2
    • Pinch the plastic plugs and lift the power supply up to detach from plugs.
    • All 4 plugs must be detached to remove power supply.
Abschluss
Phil Jones
41 Reputation
1 Anleitung geschrieben
Cal Poly, Team 5-33, Amido Fall 2011 Mitglied von Cal Poly, Team 5-33, Amido Fall 2011
CPSU-AMIDO-F11S5G33
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 13
Insgesamt: 1,209
