Zum Hauptinhalt wechseln
IBM Thinkpad T61 RAM Replacement
Was du brauchst
  1. IBM Thinkpad T61 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Ensure the laptop has been properly shut down and unplugged.
    • Turn the computer over so that you can see the battery release tab located near the top of the Thinkpad.
  2. IBM Thinkpad T61 RAM Replacement: Schritt 2, Bild 1 von 1
    • Use your finger to slide the release tab to the unlocked symbol.
  3. IBM Thinkpad T61 RAM Replacement: Schritt 3, Bild 1 von 3 IBM Thinkpad T61 RAM Replacement: Schritt 3, Bild 2 von 3 IBM Thinkpad T61 RAM Replacement: Schritt 3, Bild 3 von 3
    • Hold the tab in the unlocked position and push the battery away from the computer to remove it.
  4. IBM Thinkpad T61 RAM Replacement: Schritt 4, Bild 1 von 1
    • Slide the new battery in until it clicks.
    • Ensure that the release tab is in the locked position.
  5. IBM Thinkpad T61 RAM Replacement, RAM: Schritt 5, Bild 1 von 1
    • Using a #0 Phillips screwdriver, remove four 17.0mm screws on the back of the computer.
    • These screws have a RAM symbol next to them.
  6. IBM Thinkpad T61 RAM Replacement: Schritt 6, Bild 1 von 1
    • Flip back over and open the laptop.
    • Lift up on the inside front panel just below the edge of the keyboard.
  7. IBM Thinkpad T61 RAM Replacement: Schritt 7, Bild 1 von 1
    • The green rectangles under the front panel are the RAM.
  8. IBM Thinkpad T61 RAM Replacement: Schritt 8, Bild 1 von 3 IBM Thinkpad T61 RAM Replacement: Schritt 8, Bild 2 von 3 IBM Thinkpad T61 RAM Replacement: Schritt 8, Bild 3 von 3
    • Press out on the two tabs on either side of the ram at the same time.
    • The RAM will release and pop up at a 25 degree angle.
  9. IBM Thinkpad T61 RAM Replacement: Schritt 9, Bild 1 von 1
    • Pull the RAM away from the housing to remove.
Abschluss
15 weitere Nutzer:innen haben diese Anleitung absolviert.
Kyle
458 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 8-58, Johann Spring 2013 Mitglied von Cal Poly, Team 8-58, Johann Spring 2013
CPSU-JOHANN-S13S8G58
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 21
Letzte 30 Tage: 64
Insgesamt: 8,949
