Zum Hauptinhalt wechseln
IINE Retro Pocket Joystick Replacement
Was du brauchst
  1. IINE Retro Pocket Joystick Replacement, Remove the screws: Schritt 1, Bild 1 von 3 IINE Retro Pocket Joystick Replacement, Remove the screws: Schritt 1, Bild 2 von 3 IINE Retro Pocket Joystick Replacement, Remove the screws: Schritt 1, Bild 3 von 3
    • Set the controller down on your working surface.
    • Flip the controller over so the back of the controller is facing up, with the shoulder buttons facing away from you.
    • Use a Phillips #1 screwdriver to remove the four black 7.5mm screws from the corners of the back plate.
    Frag FixBot
    Kommentar hinzufügen
  2. IINE Retro Pocket Joystick Replacement, Remove the back plate: Schritt 2, Bild 1 von 3 IINE Retro Pocket Joystick Replacement, Remove the back plate: Schritt 2, Bild 2 von 3 IINE Retro Pocket Joystick Replacement, Remove the back plate: Schritt 2, Bild 3 von 3
    • Use the tip of an opening pick to separate the back plate. Start at the bottom corner, and pry downwards.
    • As you make your way toward the center, you will eventually disengage the retaining clips located on either side of the status LED array.
    • Be careful not to damage the retaining clips. they're small and thin, and may break easily.
    • Lift the back plate up and away from you, and set it aside.
    Frag FixBot
  3. IINE Retro Pocket Joystick Replacement: Schritt 3, Bild 1 von 1
    • Once the back plate is removed, you now have access to the internals of the controller.
    Frag FixBot
  4. IINE Retro Pocket Joystick Replacement, Disconnect the battery: Schritt 4, Bild 1 von 3 IINE Retro Pocket Joystick Replacement, Disconnect the battery: Schritt 4, Bild 2 von 3 IINE Retro Pocket Joystick Replacement, Disconnect the battery: Schritt 4, Bild 3 von 3
    • For safety and to prevent damage, disconnect the battery before continuing.
    • Locate the battery connector.
    • Use a pair of tweezers to carefully push on the notches of the battery connector and disconnect it from the socket.
    • Do not pull on the wires!
    Frag FixBot
  5. IINE Retro Pocket Joystick Replacement, Disconnect the right joystick: Schritt 5, Bild 1 von 3 IINE Retro Pocket Joystick Replacement, Disconnect the right joystick: Schritt 5, Bild 2 von 3 IINE Retro Pocket Joystick Replacement, Disconnect the right joystick: Schritt 5, Bild 3 von 3
    • Locate the ZIF connector of the right joystick.
    • Use a pair of tweezers to flip up the black flap of the ZIF connector and unlock it.
    • Disconnect the joystick cable by carefully pulling it straight out of the connector.
    Frag FixBot
  6. IINE Retro Pocket Joystick Replacement, Unscrew the right joystick: Schritt 6, Bild 1 von 2 IINE Retro Pocket Joystick Replacement, Unscrew the right joystick: Schritt 6, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the two black 3.5mm screws that secure the right joystick.
    Frag FixBot
  7. IINE Retro Pocket Joystick Replacement, Remove the right joystick: Schritt 7, Bild 1 von 2 IINE Retro Pocket Joystick Replacement, Remove the right joystick: Schritt 7, Bild 2 von 2
    • Lift up the joystick module and set it aside.
    Frag FixBot
  8. IINE Retro Pocket Joystick Replacement, Disconnect the left joystick: Schritt 8, Bild 1 von 3 IINE Retro Pocket Joystick Replacement, Disconnect the left joystick: Schritt 8, Bild 2 von 3 IINE Retro Pocket Joystick Replacement, Disconnect the left joystick: Schritt 8, Bild 3 von 3
    • Locate the ZIF connector of the left joystick.
    Frag FixBot
  9. IINE Retro Pocket Joystick Replacement, Unscrew the left joystick: Schritt 9, Bild 1 von 2 IINE Retro Pocket Joystick Replacement, Unscrew the left joystick: Schritt 9, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the two black 3.5mm screws that secure the left joystick.
    Frag FixBot
  10. IINE Retro Pocket Joystick Replacement, Remove the left joystick: Schritt 10, Bild 1 von 2 IINE Retro Pocket Joystick Replacement, Remove the left joystick: Schritt 10, Bild 2 von 2
    Frag FixBot
Abschluss
Once the controller is fully reassembled, connect it to your Nintendo Switch and calibrate the new joystick.
2 weitere Personen haben diese Anleitung absolviert.
Aardimus
75 Reputation
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 12
Letzte 30 Tage: 70
Insgesamt: 185
