Zum Hauptinhalt wechseln
Kindle Fire HD Headphone Jack Replacement
Was du brauchst
  1. Kindle Fire HD Headphone Jack Replacement, Headphone Jack: Schritt 1, Bild 1 von 1
    • 1. Using the plastic opening tool, carefully insert the opening tool on all four corners of the Kindle Fire and lift up until you hear a slight popping noise.
  2. Kindle Fire HD Headphone Jack Replacement: Schritt 2, Bild 1 von 1
    • Using the plastic opening tool, start from one corner and go around the Kindle Fire using the tool in a down and up motion to continue to pop off the backing.
    • The Kindle Fire could possibly have tape on the inside, so take caution and look before attempting to remove the back.
    • After you lift all four corners and you check for tape, it is safe to proceed.
    • Once all the plastic clips holding the screen to the plastic back of the Kindle Fire are separated, the back should be safe to lift up completely.
  3. Kindle Fire HD Headphone Jack Replacement: Schritt 3, Bild 1 von 2 Kindle Fire HD Headphone Jack Replacement: Schritt 3, Bild 2 von 2
    • Locate the headphone jack, which is by the volume buttons on the vertical edge of the Kindle.
  4. Kindle Fire HD Headphone Jack Replacement: Schritt 4, Bild 1 von 2 Kindle Fire HD Headphone Jack Replacement: Schritt 4, Bild 2 von 2
    • Using the plastic opening tool, carefully lift up the burnt orange tab that is connected to the audio board.
    • Do the same thing with the purple tab on the other side of the audio board.
  5. Kindle Fire HD Headphone Jack Replacement: Schritt 5, Bild 1 von 1
    • Using the Phillips #00 screwdriver, unscrew the two 3mm screws.
  6. Kindle Fire HD Headphone Jack Replacement: Schritt 6, Bild 1 von 1
    • The headphone jack is now safe to lift up with the plastic opening tool, and then with your hands to completely detach the headphone jack from the Kindle.
  7. Kindle Fire HD Headphone Jack Replacement: Schritt 7, Bild 1 von 1
    • Put the new headphone jack back into place. Make sure to press down all the way.
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Sam Houston State, Team 11-2, Blackburne Winter 2015 Mitglied von Sam Houston State, Team 11-2, Blackburne Winter 2015
SHSU-BLACKBURNE-W15S11G2
3 Mitglieder
9 Anleitungen geschrieben
2 Kommentare
Great guide. The only thing that wasn't on the guide that I had to do was after I put the tabs back into the new audio board I had to close the the flaps over the tabs and then it worked.
mevansku - Antwort
A question. I do not know if my Kindle Fire HD is pre or post 2013. Will this work for either one?
Kenneth Lee - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 33
Letzte 30 Tage: 145
Insgesamt: 15,665
