Zum Hauptinhalt wechseln
Kindle Fire HDX 7" Rear Panel Replacement
Was du brauchst
  1. Kindle Fire HDX 7" Rear Panel Replacement, Speaker Bezel: Schritt 1, Bild 1 von 3 Kindle Fire HDX 7" Rear Panel Replacement, Speaker Bezel: Schritt 1, Bild 2 von 3 Kindle Fire HDX 7" Rear Panel Replacement, Speaker Bezel: Schritt 1, Bild 3 von 3
    • Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
    • The adhesive is strong and may require an iOpener, or heat gun, to soften.
  2. Kindle Fire HDX 7" Rear Panel Replacement: Schritt 2, Bild 1 von 1
    • Remove the speaker bezel.
  3. Kindle Fire HDX 7" Rear Panel Replacement, Rear Panel: Schritt 3, Bild 1 von 1
    • Remove the six pink 3mm T3 Torx screws from the back case.
  4. Kindle Fire HDX 7" Rear Panel Replacement: Schritt 4, Bild 1 von 2 Kindle Fire HDX 7" Rear Panel Replacement: Schritt 4, Bild 2 von 2
    • Wedge opening picks around the perimeter between the display and back case.
    • Work the opening picks around the perimeter until the two halves disengage from each other.
    • Don't completely separate as the display ribbon cable still connects the two.
  5. Kindle Fire HDX 7" Rear Panel Replacement: Schritt 5, Bild 1 von 1
    • Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
    • There may be a glue strip between the battery and the outside case. Gently pry the case open and use the flat end of a spudger to separate the glue strip.
Abschluss
Blake Klein
70.583 Reputation
50 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 14
Insgesamt: 542
