Zum Hauptinhalt wechseln
Kindle Paperwhite 2nd Generation Screen Replacement
Was du brauchst
  1. Kindle Paperwhite 2nd Generation Screen Replacement, Screen: Schritt 1, Bild 1 von 1
    • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
    • Be sure to begin prying along the edges, these are the optimal points for removing the bezel.
  2. Kindle Paperwhite 2nd Generation Screen Replacement: Schritt 2, Bild 1 von 2 Kindle Paperwhite 2nd Generation Screen Replacement: Schritt 2, Bild 2 von 2
    • Remove the eleven 3.2 mm Phillips 000 screws from corners of mid-frame and from behind the black strip as shown.
    • Do not forget the screw in the middle of the black adhesive strip.
  3. Kindle Paperwhite 2nd Generation Screen Replacement: Schritt 3, Bild 1 von 1
    • Carefully lift and remove the mid-frame.
  4. Kindle Paperwhite 2nd Generation Screen Replacement: Schritt 4, Bild 1 von 1
    • The screen itself is glued to the mid-frame. If your replacement screen does not include the mid-frame, heat the screen with an iOpener and gently pry it from the mid-frame with a blue plastic opening tool.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Tyler Davis
1.574 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 11-2, Blackwell Fall 2016 Mitglied von USF Tampa, Team 11-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G2
4 Mitglieder
7 Anleitungen geschrieben
2 Kommentare
My opening tool is orange. Will this still work for me?
FoxRunTime - Antwort
I’m hoping to replace my screen with this part:
Kindle Paperwhite (2nd Gen) Display
Does this part include the mid-frame? I would like to avoid using the iOpener if possible.
Thank you!
Liam Cahill - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 19
Letzte 30 Tage: 69
Insgesamt: 11,698
