Zum Hauptinhalt wechseln
Kindle Voyage Battery Replacement
Was du brauchst
  1. Kindle Voyage Battery Replacement, Back Panel: Schritt 1, Bild 1 von 2 Kindle Voyage Battery Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
  2. Kindle Voyage Battery Replacement: Schritt 2, Bild 1 von 1
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
  3. Kindle Voyage Battery Replacement: Schritt 3, Bild 1 von 3 Kindle Voyage Battery Replacement: Schritt 3, Bild 2 von 3 Kindle Voyage Battery Replacement: Schritt 3, Bild 3 von 3
    • Once the screws are removed, the back panel can slide off the device.
  4. Kindle Voyage Battery Replacement: Schritt 4, Bild 1 von 2 Kindle Voyage Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the magnetic component with the magnetic head of the aluminum driver.
  5. Kindle Voyage Battery Replacement, Battery: Schritt 5, Bild 1 von 2 Kindle Voyage Battery Replacement, Battery: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    Kaufen
    • Use a plastic card to pry the battery away from the device.
    • Gently un-clip the battery plug from the device and remove the battery.
Abschluss
29 weitere Nutzer:innen haben diese Anleitung absolviert.
Sean Yap
1.283 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 19-12, Maness Winter 2015 Mitglied von Cal Poly, Team 19-12, Maness Winter 2015
CPSU-MANESS-W15S19G12
5 Mitglieder
10 Anleitungen geschrieben
15 Kommentare
Where can I buy a replacement buttery for my kindle voyage?
hegi88 - Antwort
Where to find a replacement battery for kindle voyage 3G please if any one knows
Himadri Endow - Antwort
Bump. Cannot seem to procure a new battery for the Kindle Voyage. Nice to know how to replace the old one; just need something to replace it WITH! Thanks for any hints on finding one. Battery model number is: MC-305070, 3.8V 1320mAh/5.01Wh, P/N 58-000056
larryg - Antwort
Any advance on where one can find a replacement battery for the Kindle Journal?
Charles WRIGHT - Antwort
Still looking for a source for this battery.
Neil Hall - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 14
Letzte 7 Tage: 89
Letzte 30 Tage: 444
Insgesamt: 27,320
