Zum Hauptinhalt wechseln
Krups 963 Power Switch Replacement
Was du brauchst
  1. Krups 963 Power Switch Replacement, Removing Bottom Screws: Schritt 1, Bild 1 von 1
    • Make sure the device is unplugged before continuing.
    • Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
  2. Krups 963 Power Switch Replacement: Schritt 2, Bild 1 von 1
    • Remove the single black Phillips size 0 10mm length screw on the back of the machine.
  3. Krups 963 Power Switch Replacement: Schritt 3, Bild 1 von 1
    • Remove the bottom cover from the machine and slide it down the power cord.
  4. Krups 963 Power Switch Replacement, Power Switch: Schritt 4, Bild 1 von 1
    • Use your hands or a pair of needle nose pliers to remove the wire attached to the switch.
  5. Krups 963 Power Switch Replacement: Schritt 5, Bild 1 von 1
    • Grip either in the inside or outside of the switch with the needle nose pliers or your hand, and pull to remove the switch.
Abschluss
Wyatt Hall
842 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 6-25, Maness Fall 2014 Mitglied von Cal Poly, Team 6-25, Maness Fall 2014
CPSU-MANESS-F14S6G25
4 Mitglieder
Ein Kommentar
Wyatt, thank you for the instructions. I need to replace the power switch on my Krups 963 coffee maker, but I can't find the part anywhere. Do you know where to order one from? Thanks, --Susan
susangellert - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 3,025
