Einleitung
This guide is designed to remove or replace the logic board of the LG VX6000.
Was du brauchst
Locate the dark gray tab on the back of the phone towards the top. Push the tab towards the top of the phone to release the battery.
Unscrew the six screws seen on the back using a Phillips 00 Screwdriver.
Remove screws and carefully place on an uncluttered surface or in a small container.
Carefully remove the back of the phone gently using your fingernails or tweezers.
Locate the yellow connection towards the top of the phone. This is directly connected to the screen.
Remove the connector by carefully prying it away from the motherboard and lifting it away from the phone
