Zum Hauptinhalt wechseln
Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement
Was du brauchst
  1. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: Schritt 2, Bild 1 von 2 Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: Schritt 2, Bild 2 von 2
    • Open the laptop and lay it flat.
    • Go along the edge of the keyboard with an opening tool until it pops loose.
    • Potential for device damage: Make sure that the keyboard does not fall away from the laptop, as it is still connected to the internal components
  3. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: Schritt 3, Bild 1 von 2 Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: Schritt 3, Bild 2 von 2
    • Lift the keyboard connectors up using an opening pick.
    • Remove the connectors from their sockets.
  4. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement, Headphone Jack: Schritt 4, Bild 1 von 1
    • Remove the three 4 mm Phillips #0 screws holding the headphone jack in place.
  5. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: Schritt 5, Bild 1 von 1
    • Using a plastic opening pick, remove the connection between the aux port and the speakers.
  6. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: Schritt 6, Bild 1 von 1
    • Using the plastic opening pick, pop the retaining flap holding the ribbon cable in place.
    • Remove the headphone jack from the laptop.
Abschluss
Ein Kommentar
I believe our model has the headphone jack soldered on. Any other ideas?
L Hart - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 42
Insgesamt: 907
