Zum Hauptinhalt wechseln
Lenovo Flex 6-11IGM Display Replacement
Was du brauchst
  1. Lenovo Flex 6-11IGM Display Replacement, Display: Schritt 1, Bild 1 von 2 Lenovo Flex 6-11IGM Display Replacement, Display: Schritt 1, Bild 2 von 2
    • Place the laptop face-up.
    • Open the laptop.
  2. Lenovo Flex 6-11IGM Display Replacement: Schritt 2, Bild 1 von 1
    • Using a plastic opening pick, begin to gently separate the display from the case, moving around the edge.
    • Using the plastic opening pick, begin to gently separate the plastic trim from the case, moving around the edge.
  3. Lenovo Flex 6-11IGM Display Replacement: Schritt 3, Bild 1 von 1
    • Using a Phillips #00 screwdriver, remove the three 2.5 mm screws that secure the display.
    • Secure a suction cup to the screen and pull it free from the upper case with light force.
    • Rest the display on the keyboard.
  4. Lenovo Flex 6-11IGM Display Replacement: Schritt 4, Bild 1 von 2 Lenovo Flex 6-11IGM Display Replacement: Schritt 4, Bild 2 von 2
    • Disengage the cable located at the bottom of the display.
    • Slide a plastic opening pick under the brown bar, lifting the bar up, and disengage the wire with your fingers.
    • Disengage the cable at the bottom left of the display with your fingers.
    • Disengage the cable at the top center of the display using your fingers and remove the cable from the display housing.
  5. Lenovo Flex 6-11IGM Display Replacement: Schritt 5, Bild 1 von 1
    • Remove the display.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Can you replace the digitizer separately? Or do you have to get the digitizer and lcd combo for replacement? Is it worth it at $130 for the replacement? Laptop is only a couple years old…
Tyson Strickland - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 613
