Zum Hauptinhalt wechseln
Lenovo G580 Keyboard Replacement
Was du brauchst
  1. Lenovo G580 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Place the laptop so the bottom is facing up.
  2. Lenovo G580 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the two M2.5x4 screws connecting the removable plate to the frame of the computer using a Phillips #00 screwdriver.
  3. Lenovo G580 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Using both hands, slide the plate off of the back of the laptop.
  4. Lenovo G580 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the three screws holding the keyboard to the laptop.
  5. Lenovo G580 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Open the lid of the laptop and locate the keyboard.
  6. Lenovo G580 Keyboard Replacement: Schritt 6, Bild 1 von 2 Lenovo G580 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Insert the plastic opening tool into the corner of the laptop between the keyboard and the side of the laptop.
    • Do not force the plastic opening tool as this will damage the laptop.
    • Slide the plastic opening tool across the keyboard towards the other corner.
  7. Lenovo G580 Keyboard Replacement: Schritt 7, Bild 1 von 1
    • Grab the keyboard at the corners and pull the keyboard off the laptop.
    • Make sure to disconnect the cord connecting the keyboard to the laptop before removing the keyboard.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 31
Insgesamt: 4,076
