Zum Hauptinhalt wechseln
Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement
Was du brauchst
  1. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement, Back Case: Schritt 1, Bild 1 von 1
    • Remove the thirteen 6 mm Phillips #0 screws.
  2. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 2, Bild 1 von 2 Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Use an opening tool to gently disconnect most of the clips on the back panel.
    • DO NOT force the panel out towards the optical disk drive.
  3. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 3, Bild 1 von 3 Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 3, Bild 2 von 3 Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Pry the disk drive away from the center of the laptop.
    • Don't worry about any screws since we already removed the screws that are associated with the drive.
    • Once the drive is removed, remove the one 2 mm Phillips #0 screw that is now exposed.
  4. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 4, Bild 1 von 3 Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 4, Bild 2 von 3 Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Unclip any of the remaining clips and remove the back panel.
  5. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement, Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the four 6 mm Phillips #0 mounting screws.
  6. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 6, Bild 1 von 3 Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 6, Bild 2 von 3 Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Detach the wire connected to the motherboard and remove the battery assembly.
  7. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement, Hard Disk Drive Replacement: Schritt 7, Bild 1 von 1
    • Remove the four 4 mm Phillips #0 mounting screws attaching the caddy to the frame.
  8. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 8, Bild 1 von 2 Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Gently remove the caddy away from the motherboard.
    • If you are removing an already existing HDD, unplug the component along with the caddy and remove the four screws mounting the caddy to the HDD.
  9. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement, Speaker Replacement: Schritt 9, Bild 1 von 2 Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement, Speaker Replacement: Schritt 9, Bild 2 von 2
    • Detach the speaker wire from the motherboard.
  10. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 10, Bild 1 von 2 Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Gently pull upwards on the speaker assembly to remove it from the case.
  11. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement, Motherboard Replacement: Schritt 11, Bild 1 von 3 Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement, Motherboard Replacement: Schritt 11, Bild 2 von 3 Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement, Motherboard Replacement: Schritt 11, Bild 3 von 3
    • Unlock the ZIF connector and remove the wire connected at the bottom of the motherboard.
    • For the wires with the blue plastic, you must undo the clip before pulling out the wire.
  12. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 12, Bild 1 von 3 Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 12, Bild 2 von 3 Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 12, Bild 3 von 3
    • Disconnect the wires attached on the "left" side.
    • Use the spudger to unlock the clip to remove the blue ribbon cable.
  13. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 13, Bild 1 von 3 Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 13, Bild 2 von 3 Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 13, Bild 3 von 3
    • Unlock the ZIF connector at the top-left of the motherboard.
    • Remove the ribbon cable.
  14. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 14, Bild 1 von 3 Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 14, Bild 2 von 3 Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 14, Bild 3 von 3
    • Remove the single 4 mm Philips #0 screw from the Wi-Fi card.
    • Slide the Wi-Fi card out of the socket.
  15. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 15, Bild 1 von 3 Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 15, Bild 2 von 3 Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 15, Bild 3 von 3
    • Unlock the remaining ZIF connector with a spudger.
  16. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 16, Bild 1 von 3 Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 16, Bild 2 von 3 Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 16, Bild 3 von 3
    • Disconnect the fan's wire from the motherboard.
    • Remove the four 3 mm Philips #0 screws joining the heatsink to the motherboard
    • Follow the number order when re-installing.
    • Then, remove the three 5 mm Philips #0 screws holding the fan assembly to the frame.
    • Remove the fan and heatsink.
  17. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 17, Bild 1 von 3 Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 17, Bild 2 von 3 Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 17, Bild 3 von 3
    • Once everything has been disconnected from the motherboard, remove the six 3 mm Philips #0 mounting screws from the motherboard.
    • There is normally one screw under a sticker at the "bottom" (shown in the picture).
  18. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: Schritt 18, Bild 1 von 1
    • This is what the frame should look like once everything is removed.
Abschluss
Clark Beuckman
529 Reputation
5 Anleitungen geschrieben
Clemson, Team 2-3, Hunter Spring 2022 Mitglied von Clemson, Team 2-3, Hunter Spring 2022
CLEM-HUNTER-S22S2G3
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 15
Insgesamt: 545
