Zum Hauptinhalt wechseln
Lenovo IdeaPad 300-17ISK Hard Drive Replacement
Was du brauchst
  1. Lenovo IdeaPad 300-17ISK Hard Drive Replacement, Bottom Back Cover: Schritt 1, Bild 1 von 1
    • Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
  2. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: Schritt 2, Bild 1 von 2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Place your hands at the bottom of the cover and slide it towards you.
    • Lift the cover up to remove it.
  3. Lenovo IdeaPad 300-17ISK Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 1
    • The hard drive is located at the bottom of the laptop.
  4. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the four 6mm Phillips #1 screws that hold the hard drive frame in place.
  5. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Gently pick up the hard drive without pulling it completely out.
    • You shouldn't use excessive force because the hard drive is still attached to the motherboard.
  6. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: Schritt 6, Bild 1 von 2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Use the spudger to disconnect the hard drive from it motherboard connector.
    • The connector should come right off without excessive force.
  7. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: Schritt 7, Bild 1 von 2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: Schritt 7, Bild 2 von 2
    • Remove the four 3mm Phillips #1 screws, two on each side, that secure the hard drive in its protective frame.
    • These screws are different from the rest of the laptop screws. You can damage the drive using the wrong screws.
    • Lift the frame to separate it from the hard drive.
Abschluss
10 weitere Nutzer:innen haben diese Anleitung absolviert.
Ammar Dodin
1.057 Reputation
6 Anleitungen geschrieben
UC Davis, Team 1-3, Rodger Winter 2017 Mitglied von UC Davis, Team 1-3, Rodger Winter 2017
UCD-RODGER-W17S1G3
4 Mitglieder
3 Kommentare
Clear and easy - thanks!
Beth Pierce - Antwort
Easy breezy.
danlord65 - Antwort
Very good and to the point
al_stewart - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 49
Insgesamt: 9,685
