Zum Hauptinhalt wechseln
Lenovo IdeaPad 330S Fan and Thermal Unit
Was du brauchst
  1. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing bottom case: Schritt 1, Bild 1 von 2 Lenovo IdeaPad 330S Fan and Thermal Unit, Removing bottom case: Schritt 1, Bild 2 von 2
    • Turn off the device and disconnect from the power.
    • Remove the 10 screws as shown in picture.
    • Using a plastic pry tool remove the bottom case (gently).
  2. Lenovo IdeaPad 330S Fan and Thermal Unit, Disconnecting Battery: Schritt 2, Bild 1 von 1
    • Using a spudger gently push the black connector to the left (red circle).
    • If you want to remove the battery by removing the five screws labeled in blue.
  3. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing guard shield: Schritt 3, Bild 1 von 2 Lenovo IdeaPad 330S Fan and Thermal Unit, Removing guard shield: Schritt 3, Bild 2 von 2
    • Remove the 3 screws that are circuled in blue. Then remove the red one.
    • The red circle is a M2.5 and the blue circle are M2.0 those are different screws!
    • Remove the black shield
  4. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing Cooling Fan: Schritt 4, Bild 1 von 1
    • Remove the two black screws that are marked in red
    • Disconnect the fan (blue marker) from MB by pushing gently to the left using a spudger.
  5. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing the Thermal unit: Schritt 5, Bild 1 von 1
    • Remove the 6 screws in revrse of the number stated on screws.
    • Replace the thermal paste with a fresh one
    • Removing the fan is not needed but will help with easier dissemble of thermal unit
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ilia Tocheny
1.616 Reputation
9 Anleitungen geschrieben
2 Kommentare
I want to buy this piece, where can I find it for purchase?
c.lobos_7 - Antwort
Good question, you could try at your local Lenovo Service provider.
Ilia Tocheny - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 18
Insgesamt: 1,593
