Einleitung
If your laptop is not holding a charge like it is intended to, then it may be due to your battery.
Was du brauchst
Flip laptop over so the model sticker is showing, and begin to unscrew all of the screws.
Pop off the back panel using a plastic opening tool once all screws are removed.
Use the iFixit Opening tool to disconnect the battery from the circuit board.
When all screws are removed from the battery, carefully lift the battery up.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Здравствуйте, нужны запчасти на Lenovo Flex 4-1580
1)задняя крышка!?
