Zum Hauptinhalt wechseln
Lenovo IdeaPad Flex 4-1470 Removing the Lower Case
Was du brauchst
  1. Lenovo IdeaPad Flex 4-1470 Removing the Lower Case, Lower Case: Schritt 1, Bild 1 von 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Removing the Lower Case: Schritt 2, Bild 1 von 2 Lenovo IdeaPad Flex 4-1470 Removing the Lower Case: Schritt 2, Bild 2 von 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S1-G6, Thompson Fall 2017 Mitglied von USF Tampa, Team S1-G6, Thompson Fall 2017
USFT-THOMPSON-F17S1G6
3 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
can someone please tell me where to find the back cover? i need to order it
angel etoile - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 72
Insgesamt: 19,156
