Einleitung
This is a guide for how to replace a Lenovo IdeaPad Flex 5-1470 motherboard. Common reasons to replace the motherboard are because of overheating, power surges, old age or just overuse.
Was du brauchst
Use a Phillips #00 screwdriver to remove the three screws securing the fan.
Lift the fan up and out.
Use a Phillips #00 screwdriver to remove the three screws securing the hard drive.
Lift the hard drive up and out.
Use a Phillips #00 screwdriver to remove the single screw securing the Wi-Fi card.
Pull the Wi-Fi card directly out of its port.
Use a Phillips #00 screwdriver to remove the three screws securing the motherboard.
Gently disconnect the cables and ribbon cables connected to the motherboard.
