Zum Hauptinhalt wechseln
Lenovo IdeaPad Flex 6-14IKB Battery Replacement
Was du brauchst
  1. Lenovo IdeaPad Flex 6-14IKB Battery Replacement, Base Cover: Schritt 1, Bild 1 von 1
    • Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
  2. Lenovo IdeaPad Flex 6-14IKB Battery Replacement: Schritt 2, Bild 1 von 1
    • Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
    • The goal is to unhook the plastic hooks that secure the bottom cover.
    • Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
    • You will feel and hear a clicking noise when the clips are undone.
  3. Lenovo IdeaPad Flex 6-14IKB Battery Replacement, Battery: Schritt 3, Bild 1 von 1
    • Remove the four 3.5 mm screws around the battery using a Phillips #00 screwdriver.
  4. Lenovo IdeaPad Flex 6-14IKB Battery Replacement: Schritt 4, Bild 1 von 2 Lenovo IdeaPad Flex 6-14IKB Battery Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Disconnect the battery supply from the motherboard using a pair of tweezers.
    • Remove the battery from the laptop.
    • If the battery has an adhesive patch on the underside, gently pry off the battery.
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 17
Letzte 30 Tage: 112
Insgesamt: 4,175
