Zum Hauptinhalt wechseln
Lenovo IdeaPad G50-45 Screen Replacement
Was du brauchst
  1. Lenovo IdeaPad G50-45 Screen Replacement, Screen: Schritt 1, Bild 1 von 1
    • Remove the bezel by using the iFixit plastic opening tool to lift up an edge.
    • The bezel is the plastic lining along the edge of the screen.
  2. Lenovo IdeaPad G50-45 Screen Replacement: Schritt 2, Bild 1 von 1
    • Finish removing the bezel by using your hand on the inside of the screen and popping it off.
    • If part of the bezel is stuck, start on the opposite side and work your way back to the area that is stuck.
    • The plastic on the hinges will pop off with the rest of the bezel.
  3. Lenovo IdeaPad G50-45 Screen Replacement: Schritt 3, Bild 1 von 3 Lenovo IdeaPad G50-45 Screen Replacement: Schritt 3, Bild 2 von 3 Lenovo IdeaPad G50-45 Screen Replacement: Schritt 3, Bild 3 von 3
    • Remove the 4 screws located in each corner of the screen using the Phillips #2 screwdriver.
  4. Lenovo IdeaPad G50-45 Screen Replacement: Schritt 4, Bild 1 von 1
    • Peel back the sticker that attaches the connector to the back of the screen.
    • Disconnect the cable that connects the screen to the computer.
    • There may be two cables.
  5. Lenovo IdeaPad G50-45 Screen Replacement: Schritt 5, Bild 1 von 1
    • Test the new screen by turning it on before putting the bezel back on.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team 2-6, Shastany Fall 2015 Mitglied von UMass Dartmouth, Team 2-6, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G6
3 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
The tutorial was pretty straightforward, and worked.
Remy G - Antwort
My Laptop is got work the searen is blue it what trun on
Rebecca - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 27
Insgesamt: 7,845
