Zum Hauptinhalt wechseln
Lenovo Ideapad 320-15ABR Hard Drive Replacement
Was du brauchst
  1. Lenovo Ideapad 320-15ABR Hard Drive Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Before you proceed, make sure your computer is turned off and is not connected to any power source.
    • Remove the single 7 mm Phillips #1 screw securing the optical drive.
    • Be sure to store the screws carefully as they are easy to lose. A magnetic project mat is recommended
  2. Lenovo Ideapad 320-15ABR Hard Drive Replacement: Schritt 2, Bild 1 von 3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: Schritt 2, Bild 2 von 3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
  3. Lenovo Ideapad 320-15ABR Hard Drive Replacement: Schritt 3, Bild 1 von 2 Lenovo Ideapad 320-15ABR Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
  4. Lenovo Ideapad 320-15ABR Hard Drive Replacement: Schritt 4, Bild 1 von 3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: Schritt 4, Bild 2 von 3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: Schritt 4, Bild 3 von 3
    • Use an opening tool to pry out the back cover.
  5. Lenovo Ideapad 320-15ABR Hard Drive Replacement: Schritt 5, Bild 1 von 3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: Schritt 5, Bild 2 von 3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Remove the back panel by pulling it up and away from the laptop.
  6. Lenovo Ideapad 320-15ABR Hard Drive Replacement, Hard Drive: Schritt 6, Bild 1 von 2 Lenovo Ideapad 320-15ABR Hard Drive Replacement, Hard Drive: Schritt 6, Bild 2 von 2
    • Before removing the drive, make a backup copy of all the information on it if possible. Never remove the drive while the system is operating or in suspend mode.
    • Gently lift up the hard disk from the left.
  7. Lenovo Ideapad 320-15ABR Hard Drive Replacement: Schritt 7, Bild 1 von 3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: Schritt 7, Bild 2 von 3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: Schritt 7, Bild 3 von 3
    • Do not lift hard drive straight up as it risks breaking the connection port.
    • Carefully pull the hard drive away and out of the connection port.
  8. Lenovo Ideapad 320-15ABR Hard Drive Replacement: Schritt 8, Bild 1 von 3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: Schritt 8, Bild 2 von 3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: Schritt 8, Bild 3 von 3
    • Detach the bracket from the hard drive by pulling the bracket edges apart.
Abschluss
25 weitere Nutzer:innen haben diese Anleitung absolviert.
Anurag Deb
1.045 Reputation
3 Anleitungen geschrieben
4 Kommentare
What is the maximum thickness of the replacement Hard Drive/SSD.
Drew Howden - Antwort
It takes a standard 2.5” laptop HDD/SSD. They do not vary in thickness.
TheSolderSnake -
@TheSolderSnake You might want to use google to see the variation in 2.5” laptop drive thickness before making such a confident statement. ;)
Ben - Antwort
This is gonna be fun! lol. I’ll be doing this in 5-15 minutes. Wish me luck!!!
Paul Hucik Jr - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 48
Letzte 30 Tage: 205
Insgesamt: 23,803
