Zum Hauptinhalt wechseln
Lenovo Ideapad 320-15IAP Hard Drive Replacement
Was du brauchst
  1. Lenovo Ideapad 320-15IAP Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 2 Lenovo Ideapad 320-15IAP Hard Drive Replacement, Hard Drive: Schritt 1, Bild 2 von 2
    • Using a Phillips #0 screwdriver, unscrew all thirteen 6.5 mm screws from the back panel.
  2. Lenovo Ideapad 320-15IAP Hard Drive Replacement: Schritt 2, Bild 1 von 2 Lenovo Ideapad 320-15IAP Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Remove the CD reader with an opening tool. It is possible you have to apply a substantial amount of force so watch your fingers while doing so.
    • Lift the cover using the opening tool on different spots along the side of the laptop.
  3. Lenovo Ideapad 320-15IAP Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Remove the hard drive by inserting your finger under the highlighted area, then pushing up then pulling left to remove the drive.
    • Remove the adapter from the drive, then insert the new drive into the adapter.
    • To insert the new drive, gently place it into the enclosure for the hard drive and push carefully into the SATA slot.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 29
Insgesamt: 1,224
