Zum Hauptinhalt wechseln
Lenovo Ideapad 330-15ARR Fan Assembly Replacement
Was du brauchst
  1. Lenovo Ideapad 330-15ARR Fan Assembly Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • Remove all Phillips #0 screws securing the case to the laptop.
  2. Lenovo Ideapad 330-15ARR Fan Assembly Replacement: Schritt 2, Bild 1 von 2 Lenovo Ideapad 330-15ARR Fan Assembly Replacement: Schritt 2, Bild 2 von 2
    • Pry all edges off of the laptop with the opening tool until the lower case releases.
    • Remove the lower case.
  3. Lenovo Ideapad 330-15ARR Fan Assembly Replacement, Fan Assembly: Schritt 3, Bild 1 von 2 Lenovo Ideapad 330-15ARR Fan Assembly Replacement, Fan Assembly: Schritt 3, Bild 2 von 2
    • Unscrew all three captive screws attaching the heat sink to the motherboard with a Phillips #0 screwdriver.
    • These screws stay attached to the heatsink, so do not attempt to remove them.
  4. Lenovo Ideapad 330-15ARR Fan Assembly Replacement: Schritt 4, Bild 1 von 2 Lenovo Ideapad 330-15ARR Fan Assembly Replacement: Schritt 4, Bild 2 von 2
    • Remove the three Phillips #0 screws securing the fan assembly.
  5. Lenovo Ideapad 330-15ARR Fan Assembly Replacement: Schritt 5, Bild 1 von 3 Lenovo Ideapad 330-15ARR Fan Assembly Replacement: Schritt 5, Bild 2 von 3 Lenovo Ideapad 330-15ARR Fan Assembly Replacement: Schritt 5, Bild 3 von 3
    • Take the wires in your hand, and firmly but gently pull it out of its port.
    • Lift the fan assembly out of the device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 20
Insgesamt: 315
