Zum Hauptinhalt wechseln
Lenovo Ideapad 330-15ARR Speaker Replacement
Was du brauchst
  1. Lenovo Ideapad 330-15ARR Speaker Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • Remove all Phillips #0 screws securing the case to the laptop.
  2. Lenovo Ideapad 330-15ARR Speaker Replacement: Schritt 2, Bild 1 von 2 Lenovo Ideapad 330-15ARR Speaker Replacement: Schritt 2, Bild 2 von 2
    • Pry all edges off of the laptop with the opening tool until the lower case releases.
    • Remove the lower case.
  3. Lenovo Ideapad 330-15ARR Speaker Replacement, Speaker: Schritt 3, Bild 1 von 2 Lenovo Ideapad 330-15ARR Speaker Replacement, Speaker: Schritt 3, Bild 2 von 2
    • Remove the speaker's motherboard connection.
  4. Lenovo Ideapad 330-15ARR Speaker Replacement: Schritt 4, Bild 1 von 3 Lenovo Ideapad 330-15ARR Speaker Replacement: Schritt 4, Bild 2 von 3 Lenovo Ideapad 330-15ARR Speaker Replacement: Schritt 4, Bild 3 von 3
    • Each speaker has multiple plastic connection points - simply pull upwards and they should easily slide off of them.
    • Remove the speaker.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 152
