Einleitung
If the laptop is lagging, and the mouse is slow to react, use this guide to replace your hard drive.
Was du brauchst
Remove the nine 6 mm screws using a T5 Torx Screwdriver.
Remove the two 10 mm screws using a T5 Torx Screwdriver.
Use a plastic opening tool to carefully pry off the back cover.
Remove the back cover.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
