Einleitung
The battery can possibly die quickly although the laptop can turn on when the charging cord is connected. This issue is the result of needing a battery replacement. This guide will show how to remove and replace your battery.
Was du brauchst
Begin by turning your closed laptop so that you are looking at the bottom panel.
Locate the 10 screws (6mm) around the border of the panel.
Using the Torx T5 Screwdriver, remove the screws.
Now that the screws are removed, gently lift the back panel upwards to detach it from the rest of your laptop.
Locate the battery in the bottom right corner.
Using a Phillips #000, remove the 6 screws (3.5mm) on the border of the battery and the 7th screw (6.5mm) that is in the center of the battery.
There may be tape around the edge of the battery to secure some wires. Use a pair of tweezers to remove the tape so that the wires are no longer attached to the battery.
After you have unscrewed the screws, unplugged the cable, and removed the tape and wires, you can remove the battery from your laptop.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
