Einleitung
This guide illustrates how to remove the screen for a Lenovo Legion Y530-15ICH which may become pixelated or damaged. A user may even want to replace the factory screen with a higher quality screen for better performance.
Was du brauchst
Firmly insert the opening pick under the plastic bezel surrounding the screen.
Work your way around the bezel until it is completely removeable.
Remove the bezel from the display.
Carefully insert the plastic opening tool behind the screen to remove the adhesive.
Using a small metal spudger, disconnet the LCD connector.
Carefully remove the screen from the device.
