Zum Hauptinhalt wechseln
Lenovo Legion Y530-15ICH Speaker Replacement
Was du brauchst
  1. Lenovo Legion Y530-15ICH Speaker  Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7 mm screws
    • Six 4 mm screws
  2. Lenovo Legion Y530-15ICH Speaker  Replacement: Schritt 2, Bild 1 von 2 Lenovo Legion Y530-15ICH Speaker  Replacement: Schritt 2, Bild 2 von 2
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH Speaker  Replacement, Battery: Schritt 3, Bild 1 von 1
    • Use a Phillips screwdriver to remove the five 4 mm screws holding the battery in place.
  4. Lenovo Legion Y530-15ICH Speaker  Replacement: Schritt 4, Bild 1 von 2 Lenovo Legion Y530-15ICH Speaker  Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    • Now you can safely remove the battery.
  5. Lenovo Legion Y530-15ICH Speaker  Replacement, Speaker: Schritt 5, Bild 1 von 1
    • Remove the five screws using the Phillips #0 screwdriver.
  6. Lenovo Legion Y530-15ICH Speaker  Replacement: Schritt 6, Bild 1 von 1
    • Gently peel up the copper adhesive.
  7. Lenovo Legion Y530-15ICH Speaker  Replacement: Schritt 7, Bild 1 von 1
    • Remove the speakers from the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 50
Insgesamt: 1,260
