Zum Hauptinhalt wechseln
Lenovo N21 Chromebook Battery Replacement
Was du brauchst
  1. Lenovo N21 Chromebook Battery Replacement, Keyboard and Trackpad Panel: Schritt 1, Bild 1 von 2 Lenovo N21 Chromebook Battery Replacement, Keyboard and Trackpad Panel: Schritt 1, Bild 2 von 2
    • Power down the Chromebook before starting any repair.
    • Opening up your Chromebook voids the manufacturer warranty.
    • Use a screwdriver to remove the six 5.0mm Phillips screws from the bottom housing of the Chromebook.
  2. Lenovo N21 Chromebook Battery Replacement: Schritt 2, Bild 1 von 2 Lenovo N21 Chromebook Battery Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool to pry off the four rubber pegs from the bottom housing.
  3. Lenovo N21 Chromebook Battery Replacement: Schritt 3, Bild 1 von 2 Lenovo N21 Chromebook Battery Replacement: Schritt 3, Bild 2 von 2
    • Use a screwdriver to remove the four 5.0mm Phillips screws located under the rubber soles.
  4. Lenovo N21 Chromebook Battery Replacement: Schritt 4, Bild 1 von 3 Lenovo N21 Chromebook Battery Replacement: Schritt 4, Bild 2 von 3 Lenovo N21 Chromebook Battery Replacement: Schritt 4, Bild 3 von 3
    • Flip the laptop over and open the screen.
    • Gently pry the keyboard and trackpad panel away from the bottom housing using a plastic opening tool.
    • Once completely separated, do not immediately pull the panel completely away from the bottom housing. There are wires that are still connecting the panel to the rest of the internals of the Chromebook.
  5. Lenovo N21 Chromebook Battery Replacement: Schritt 5, Bild 1 von 2 Lenovo N21 Chromebook Battery Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the keyboard ribbon cable by lifting the ZIF connector lock with a plastic opening tool or fingernail and gently pulling the ribbon cable straight out of its socket.
  6. Lenovo N21 Chromebook Battery Replacement: Schritt 6, Bild 1 von 3 Lenovo N21 Chromebook Battery Replacement: Schritt 6, Bild 2 von 3 Lenovo N21 Chromebook Battery Replacement: Schritt 6, Bild 3 von 3
    • Disconnect the trackpad ribbon cable by lifting the ZIF connector lock with a small prying tool or fingernail and gently pulling the ribbon cable straight out of its socket.
  7. Lenovo N21 Chromebook Battery Replacement: Schritt 7, Bild 1 von 1
    • Remove the keyboard and trackpad panel away from the device.
  8. Lenovo N21 Chromebook Battery Replacement, Battery: Schritt 8, Bild 1 von 3 Lenovo N21 Chromebook Battery Replacement, Battery: Schritt 8, Bild 2 von 3 Lenovo N21 Chromebook Battery Replacement, Battery: Schritt 8, Bild 3 von 3
    • Disconnect the white charging cable connectors by pulling straight down on the connector.
  9. Lenovo N21 Chromebook Battery Replacement: Schritt 9, Bild 1 von 2 Lenovo N21 Chromebook Battery Replacement: Schritt 9, Bild 2 von 2
    • Use a Phillips screwdriver to remove the three 3mm screws located along the edge of the battery.
  10. Lenovo N21 Chromebook Battery Replacement: Schritt 10, Bild 1 von 1
    • Peel up on the silver cable enough to remove the adhesive to the battery.
    • When moving the adhesive cable, be careful not to disconnect or damage the cable and motherboard.
  11. Lenovo N21 Chromebook Battery Replacement: Schritt 11, Bild 1 von 1
    • Remove the battery by pulling back and up.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S21-G2, Livingston Spring 2017 Mitglied von Cal Poly, Team S21-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G2
4 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Great step by step instructions!
M Mikusa - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 42
Insgesamt: 8,960
