Zum Hauptinhalt wechseln
Lenovo N22 Chromebook Battery Replacement
Was du brauchst
  1. Lenovo N22 Chromebook Battery Replacement, Keyboard: Schritt 1, Bild 1 von 3 Lenovo N22 Chromebook Battery Replacement, Keyboard: Schritt 1, Bild 2 von 3 Lenovo N22 Chromebook Battery Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Power down the Chromebook before starting the repair.
    • Opening the Chromebook voids the manufacturer warranty.
    • Flip the Chromebook so that the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove the six 6.6 mm screws on the bottom.
    • Use a spudger to remove each of the 4 rubber feet.
    • Use a Phillips #1 screwdriver to remove the four additional screws under the rubber feet.
  2. Lenovo N22 Chromebook Battery Replacement: Schritt 2, Bild 1 von 3 Lenovo N22 Chromebook Battery Replacement: Schritt 2, Bild 2 von 3 Lenovo N22 Chromebook Battery Replacement: Schritt 2, Bild 3 von 3
    • Flip the Chromebook back over and open the screen.
    • Wedge the plastic opening tool between the keyboard and the bottom of the Chromebook.
    • Run the plastic opening tool along the seam between the keyboard and the bottom of the Chromebook until the keyboard moves freely. Several tabs will pop out.
    • It is normal for the tabs to make a loud click when released. The corner tabs will be harder to release than the others and will make a louder click.
  3. Lenovo N22 Chromebook Battery Replacement: Schritt 3, Bild 1 von 2 Lenovo N22 Chromebook Battery Replacement: Schritt 3, Bild 2 von 2
    • Once the keyboard is released, grab the two top corners closest to the screen and slowly lift the keyboard up.
    • Do not lift the keyboard quickly or you might break the two cables that connect the keyboard to the motherboard.
    • Disconnect the cables by lifting up the retaining flaps on the black ZIF connectors.
    • Slowly pull the cables up and out of the connectors.
  4. Lenovo N22 Chromebook Battery Replacement: Schritt 4, Bild 1 von 1
    • Lift the keyboard up and off the back panel, exposing the motherboard and battery.
  5. Lenovo N22 Chromebook Battery Replacement, Battery: Schritt 5, Bild 1 von 2 Lenovo N22 Chromebook Battery Replacement, Battery: Schritt 5, Bild 2 von 2
    • Separate the battery cable from the motherboard by wedging the edge of a plastic opening tool between the black cable connector and the silver socket on the motherboard.
    • Pull the battery cable straight towards you, away from the silver socket.
  6. Lenovo N22 Chromebook Battery Replacement: Schritt 6, Bild 1 von 2 Lenovo N22 Chromebook Battery Replacement: Schritt 6, Bild 2 von 2
    • Use a Philips #1 screwdriver to remove the three 4.3 mm screws securing the battery.
  7. Lenovo N22 Chromebook Battery Replacement: Schritt 7, Bild 1 von 2 Lenovo N22 Chromebook Battery Replacement: Schritt 7, Bild 2 von 2
    • Lift up on the tabs that were held down by the screws to remove the battery.
Abschluss
10 weitere Nutzer:innen haben diese Anleitung absolviert.
Kevin Yerina
453 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S21-G1, Livingston Spring 2017 Mitglied von Cal Poly, Team S21-G1, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G1
4 Mitglieder
14 Anleitungen geschrieben
4 Kommentare
amazing!! thank you
Mark safoo - Antwort
thanks I needed to take the bottom off so I can take a certain screw
xian panadero - Antwort
cuck trentxluka
Jonathan Fritz - Antwort
That's way too much just to take the battery out. it was helpful having these steps. Thank you
Becky Breneman - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 56
Insgesamt: 16,674
