Zum Hauptinhalt wechseln
Lenovo ThinkPad T440p Keyboard Replacement
Was du brauchst
  1. Lenovo ThinkPad T440p Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop so that the back is facing up.
  2. Lenovo ThinkPad T440p Keyboard Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad T440p Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Slide the battery latches to the unlocked position.
  3. Lenovo ThinkPad T440p Keyboard Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad T440p Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Slide the battery pack out of the battery slot.
  4. Lenovo ThinkPad T440p Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 3 Lenovo ThinkPad T440p Keyboard Replacement, Keyboard: Schritt 4, Bild 2 von 3 Lenovo ThinkPad T440p Keyboard Replacement, Keyboard: Schritt 4, Bild 3 von 3
    • Using the spudger, move the plastic protector by pressing it down and forward in order to uncover the screws.
  5. Lenovo ThinkPad T440p Keyboard Replacement: Schritt 5, Bild 1 von 2 Lenovo ThinkPad T440p Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Don't remove the screws; just loosen them.
    • Unscrew the six screws that are attached to the keyboard by using a Phillips #00 screwdriver.
  6. Lenovo ThinkPad T440p Keyboard Replacement: Schritt 6, Bild 1 von 3 Lenovo ThinkPad T440p Keyboard Replacement: Schritt 6, Bild 2 von 3 Lenovo ThinkPad T440p Keyboard Replacement: Schritt 6, Bild 3 von 3
    • Use the spudger to lift the keyboard.
  7. Lenovo ThinkPad T440p Keyboard Replacement: Schritt 7, Bild 1 von 2 Lenovo ThinkPad T440p Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Turn the keyboard over.
  8. Lenovo ThinkPad T440p Keyboard Replacement: Schritt 8, Bild 1 von 3 Lenovo ThinkPad T440p Keyboard Replacement: Schritt 8, Bild 2 von 3 Lenovo ThinkPad T440p Keyboard Replacement: Schritt 8, Bild 3 von 3
    • Use the spudger to detach the plastic protection.
  9. Lenovo ThinkPad T440p Keyboard Replacement: Schritt 9, Bild 1 von 3 Lenovo ThinkPad T440p Keyboard Replacement: Schritt 9, Bild 2 von 3 Lenovo ThinkPad T440p Keyboard Replacement: Schritt 9, Bild 3 von 3
    • Use the spudger to disconnect the cables.
  10. Lenovo ThinkPad T440p Keyboard Replacement: Schritt 10, Bild 1 von 1
    • Remove the keyboard.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Christian Abad
1.378 Reputation
7 Anleitungen geschrieben
UMass Dartmouth, Team S6-G5, Peak Spring 2019 Mitglied von UMass Dartmouth, Team S6-G5, Peak Spring 2019
UMASSD-PEAK-S19S6G5
3 Mitglieder
9 Anleitungen geschrieben
Ein Kommentar
Thanks for the guide. I hate this part lol.
is it true if I slip and knock keys off, they can’t be lit in? I’m told this and it seems true :(
Josh Tree - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 20
Letzte 30 Tage: 57
Insgesamt: 7,050
