Zum Hauptinhalt wechseln
Lenovo ThinkPad T460s RAM Replacement
Was du brauchst
  1. Lenovo ThinkPad T460s RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Remove the five 5.5mm Phillips #1 screws securing the back cover.
    • These screws are captive and cannot be removed completely from the back cover.
    • Lift and remove the back cover.
  2. Lenovo ThinkPad T460s RAM Replacement: Schritt 2, Bild 1 von 1
    • Remove the five 5.5mm Phillips #1 screws securing the two batteries.
  3. Lenovo ThinkPad T460s RAM Replacement: Schritt 3, Bild 1 von 1
    • Unplug the two-wire connector from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  4. Lenovo ThinkPad T460s RAM Replacement: Schritt 4, Bild 1 von 3 Lenovo ThinkPad T460s RAM Replacement: Schritt 4, Bild 2 von 3 Lenovo ThinkPad T460s RAM Replacement: Schritt 4, Bild 3 von 3
    • Each battery has a black tab covering the electrical contacts.
    • Lift the battery by its tab and remove it from the device.
  5. Lenovo ThinkPad T460s RAM Replacement, RAM: Schritt 5, Bild 1 von 3 Lenovo ThinkPad T460s RAM Replacement, RAM: Schritt 5, Bild 2 von 3 Lenovo ThinkPad T460s RAM Replacement, RAM: Schritt 5, Bild 3 von 3
    • To remove the existing RAM module, pull tabs marked in the red outwards.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 30
Letzte 30 Tage: 108
Insgesamt: 4,494
