Zum Hauptinhalt wechseln
Lenovo ThinkPad T460s Wi-Fi Card Replacement
Was du brauchst
  1. Lenovo ThinkPad T460s Wi-Fi Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Remove the five 5.5mm Phillips #1 screws securing the back cover.
    • These screws are captive and cannot be removed completely from the back cover.
    • Lift and remove the back cover.
  2. Lenovo ThinkPad T460s Wi-Fi Card Replacement: Schritt 2, Bild 1 von 1
    • Remove the five 5.5mm Phillips #1 screws securing the two batteries.
  3. Lenovo ThinkPad T460s Wi-Fi Card Replacement: Schritt 3, Bild 1 von 1
    • Unplug the two-wire connector from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  4. Lenovo ThinkPad T460s Wi-Fi Card Replacement: Schritt 4, Bild 1 von 3 Lenovo ThinkPad T460s Wi-Fi Card Replacement: Schritt 4, Bild 2 von 3 Lenovo ThinkPad T460s Wi-Fi Card Replacement: Schritt 4, Bild 3 von 3
    • Each battery has a black tab covering the electrical contacts.
    • Lift the battery by its tab and remove it from the device.
  5. Lenovo ThinkPad T460s Wi-Fi Card Replacement, Wi-Fi Card: Schritt 5, Bild 1 von 3 Lenovo ThinkPad T460s Wi-Fi Card Replacement, Wi-Fi Card: Schritt 5, Bild 2 von 3 Lenovo ThinkPad T460s Wi-Fi Card Replacement, Wi-Fi Card: Schritt 5, Bild 3 von 3
    • Disconnect the gray and black cables from the Wi-Fi card.
    • Remove the 3mm Phillips #1 screw on the chip.
    • Remove the Wi-Fi card from the device.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
which replacement modules would you recommend? I am looking for alternatives to the 8260 that seems to be flawed.
albert einstein - Antwort
I have now replaced my Wifi-Card and just wanted to point that you instructions diverge from the official ones suggested by Lenovo. This manual simply recommends to deactivate the internal batteries through a bios option - which seems easier than the instructions laid out here.
still, cheers for your guide.
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 42
Insgesamt: 3,103
