Einleitung
This guide will show you how to safely remove the screen from the Lenovo ThinkPad T495s. Before embarking on this process, refer to the link below for troubleshooting monitor issues to avoid unnecessary changes. A screen may need to be removed due to a cracked screen, broken LCD, dysfunctional touch screen, or to access the hardware behind the monitor. To replace a screen, reverse the steps followed in the guide. Use caution when prying off the connections with an iFixit opening tool and tweezer to ensure no further damage.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:Tweezers$3.99
Use the angled tweezers to lift the adhesive plastic above the connection.
To separate the display cable connector, gently wedge your opening tool under the clip. Then, swing the clip over to the other side of the socket, so that it lays flat against the cable.
Pull in the direction of the cable to disconnect it.
