Einleitung
Follow this guide to replace the hard drive, or solid state drive in your Lenovo T530/T530i.
Was du brauchst
Flip your laptop upside down, so that the keyboard is facing down.
Locate the latch located on the battery near the top of the laptop.
Using your finger, slide the latch to the right-most (Unlocked) position.
You can now pull the battery away from the laptop. When pulling the battery out, ensure to pull it out straight.
Using a Phillips #00 screwdriver, remove the bottom screw to unlock the storage drive cover.
Lift up the storage drive cover from the lip highlighted in orange. Put it aside.
Grab the rubber spacers highlighted in red, and pull them away from the drive.
Using a Phillips #00 screwdriver, unscrew the four screws, two on each of the left, and right side of the drive.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
